mrmodi
Aug 30, 2016Aspirant
Router needs to restart every time to connect internet
Hello sir, I have GTPL Broadband Connection. I need to restart it every time for connecting to internet. As the GTPL technical said that Netgear router release IP as you close your router. Once...
- Sep 09, 2016I tried my best with netgear router. But it is not compatible with gtpl broadband isp. It doesn,'t work properly.
So let me buy another company's router suggested by gtpl broadband technical person.
ElaineM
Aug 31, 2016NETGEAR Employee Retired
Hi mrmodi
Welcome to the community!
What's happening with the router that you need to always restart it?
Is your connection stable when you connect your computer directly to the modem?
If yes, make sure that you select "Use Computer MAC Address" on the router settings.
