mrmodi
Aug 30, 2016Aspirant
Router needs to restart every time to connect internet
Hello sir, I have GTPL Broadband Connection. I need to restart it every time for connecting to internet. As the GTPL technical said that Netgear router release IP as you close your router. Once...
- Sep 09, 2016I tried my best with netgear router. But it is not compatible with gtpl broadband isp. It doesn,'t work properly.
So let me buy another company's router suggested by gtpl broadband technical person.
mrmodi
Aug 31, 2016Aspirant
I have already selected Use Computer MAC Address.
- ElaineMAug 31, 2016NETGEAR Employee Retired
What's the firmware version installed on your router?
See if reflashing/upgrading firmware will help. By the way, if you decided to upgrade do not forget to factory reset the router.
