mrmodi
Aug 30, 2016Aspirant
Router needs to restart every time to connect internet
Hello sir, I have GTPL Broadband Connection. I need to restart it every time for connecting to internet. As the GTPL technical said that Netgear router release IP as you close your router. Once...
- Sep 09, 2016I tried my best with netgear router. But it is not compatible with gtpl broadband isp. It doesn,'t work properly.
So let me buy another company's router suggested by gtpl broadband technical person.
mrmodi
Sep 02, 2016Aspirant
Sorry for delay reply.
I disagree with your reply because it is working perfectly with other broadband service like tikona etc.
It has only issue with gtpl broadband.
netwrks
Sep 02, 2016Master
If you feel it works properly with other ISP's assuming you have recently tried (as in days not months) your router on another ISP Service, then you should be calling your ISP to work, to resolve the issue.
