mrmodi
Aug 30, 2016Aspirant
Router needs to restart every time to connect internet
Hello sir, I have GTPL Broadband Connection. I need to restart it every time for connecting to internet. As the GTPL technical said that Netgear router release IP as you close your router. Once...
- Sep 09, 2016I tried my best with netgear router. But it is not compatible with gtpl broadband isp. It doesn,'t work properly.
So let me buy another company's router suggested by gtpl broadband technical person.
mrmodi
Sep 02, 2016Aspirant
I have borrow my friend's netgear router same as mine and try to test but the same issue happen with that router also. I discussed with gtpl technician about that but he told its netgear router fault. He suggested me to buy other company's router. So i assume that netgear router is not vompatible with gtpl isp service.
