mrmodi
Aug 30, 2016Aspirant
Router needs to restart every time to connect internet
Hello sir, I have GTPL Broadband Connection. I need to restart it every time for connecting to internet. As the GTPL technical said that Netgear router release IP as you close your router. Once...
- Sep 09, 2016I tried my best with netgear router. But it is not compatible with gtpl broadband isp. It doesn,'t work properly.
So let me buy another company's router suggested by gtpl broadband technical person.
mrmodi
Sep 07, 2016Aspirant
Yes.
ElaineM
Sep 07, 2016NETGEAR Employee Retired
Is it possible to use another router aside from the ones you used for further isolation?
The one from your friend, connects but it is not stable, right?
Most sites would just recommend to just use the step that was given previously.
