terryb44805
Jan 11, 2016Aspirant
Router non responsive - WNR2000v5
I went to update the router within the Netgear Genie program. It failed to update but then the lights went out and now the power light is slowly blinking. Which as I read means a firmware problem. ...
Babylon5
Jan 12, 2016NETGEAR Employee Retired
Maybe this will help? But have you first of all just tried a factory reset?
- terryb44805Jan 12, 2016Aspirant
Hi. I did try a factory reset and that didn't work. Tried the procedure you suggested but still nothing. The green power light just keeps slowly blinking.
