NOKOMIS_7
Dec 19, 2024Aspirant
Router not accepting connections
Router not accepting connections. Ethernet port 3 has orange light. Router has been reset. Aside from the orange light the router appears to initiate after reset in a normal manor. The light in ethe...
NOKOMIS_7
I have noticed than when I connect to it via any other ethernet port, I get the standard ips, on a 192.168.1.x network with a 255.255.255.0 subnet , the gateway listed as 192.168.1.1. When connecting to the "malfunctioning" port number 3, the ips and network are not the same. It assigns an IP of 169.254.192.35 and a subnet of 255.255.0.0 there is no gateway listed.
