jmyrtle
Aug 11, 2018Aspirant
Router Not Providing ISP speeds
My family and I decided to upgrade our internet speed with our ISP. We joined Spectrum with internet speeds at 200Mbps. We were told by Spectrum that our router wasn't powerful enough to push the spe...
- Aug 14, 2018
We ended up returning the router and purchased the AC1750 (R6400). This router appears to be handling the speeds quite well now. Is there anything you guys suggest to improve speed and quality of the internet connections over Wi-Fi? This is still a work in progress for my family and I.
jmyrtle
Aug 14, 2018Aspirant
michaelkenward
Aug 14, 2018Guru - Experienced User
Apart from the obvious, see above, there isn't a lot you can do beyond ensuring that the router is suitably positioned so that all the wifi clients can "see" it.
If you experience any problems, check to see if there is any wifi interference from the neighbours, if there are any.
Use 5GHz wifi as much as possible, it is faster but has a shorter range.
Wifi speeds depend on the wifi clients as well as the router, so they should be updated if necessary.
Of course, it all depends on whaty you are doing, reading email is less of a strain on the wifi than playing games.
Where possible use wired connections. especially for things that don't move around. For example, I use Powerline Ethernet to connect smart TVs and radios.
- michaelkenwardAug 14, 2018Guru - Experienced User
PS Update the firmware on the router before you make too many complicated changes.
