Wanbli61
Jul 29, 2017Aspirant
Router not working
Unit turns on and the first 2 lights on left are on, but no other activity. Not found on any wifi searches within home... Like it doesn't exist anymore - was working just fine!
- Aug 01, 2017
Well done. Don't beat yourself up. You are not the first person, and won't be the last, to be confused by those "buttons".
Mark you reply as "solved" and it could help one of those later victims to find the solution.
Wanbli61
Jul 31, 2017Aspirant
Well embarrassingly enough, you led directly to the problem! I discovered my wifi light (which I was unaware was also a button) was somehow turned off! Turning back on solved all my ills! Thank you partner!
michaelkenward
Aug 01, 2017Guru - Experienced User
