aur2jcp
Feb 16, 2022Follower
router password not working with extender AC1200 dual band wifi range extender model EX6110
I have used the WPS and all lights are green. When I go to connect the extender, the router password (and I'm positive it's the correct password) will not work for the extender. When I go to find t...
Feb 17, 2022Guru - Experienced User
Try factory resetting the extender (push and hold reset for 7-15 seconds while powered on).
Then install it using the installation assistant and NOT wps. I've seen wps get coded poorly with some routers and not work properly.
when it doesn't work properly, usually the installation assistant will.
