aur2jcp
Feb 16, 2022Follower
router password not working with extender AC1200 dual band wifi range extender model EX6110
I have used the WPS and all lights are green. When I go to connect the extender, the router password (and I'm positive it's the correct password) will not work for the extender. When I go to find t...
michaelkenward
Feb 17, 2022Guru
aur2jcp wrote:
When I try to connect using the router's password, it tells me wrong password.
Remember, the extender's admin password is not the same as the wifi password. The default values for both are on a label on the device.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
