pePaolo
Dec 10, 2016Aspirant
Router pr2000 n300 Trek bricked
Hi there, this is Paolo, I have a Netgear pr2000 trek bricked by wrong firmware, green power led working, green internet led working, green usb led blinking, sometimes green wifi led blinking. ip...
- Dec 12, 2016
Welcome to the community, pePaolo
What firmware did you use?
You may try re-uploading the correct firmware by following the link below.
pePaolo
Dec 12, 2016Aspirant
Elaine, Many thanks for your answer. I unsuccessfully tried many times this guide...
- Unplug all port connections from router except the PC you are using to upload.
- Turn router OFF for 10 seconds.
- Hold down the reset button on the back of router with a paper clip.
- Power ON the router while holding down the reset button.
- Watch the Power LED. It starts with orange color, and then will start flashing orange.
- Power LED will then turn to flashing green. Count at least 10 flashing green LED and release the reset button.
- Click Upgrade button on the tftp2 utility to do firmware upgrade
Is it good for any netgear router? The pr2000 trek has no orange led, but 4 green leds, and if I try tftp2 it goes in timeout.
and if I keep pushing reset and turn on the power of the pr2000 the usb green led starts blinking, but again tftp2 goes in timeout.
Nobody else with the same issue?
ElaineM
Dec 12, 2016NETGEAR Employee Retired
If it can't be restored then it's totally bricked.
