Pablo777
Sep 13, 2021Tutor
Router Problem with WIFI
Pablo777 Novice 2021-09-13 10:16 AM I have Internet using Cat 5 cable but my other wireless divices like cell phones and TV's say:"Connected, no Internet. Ple...
- Sep 16, 2021
I bought a new router R6850 AC2000 and installed it correctly and all is well now. Thank you for your help.
Sep 13, 2021Guru - Experienced User
You have the R6400?
What modem/gateway is it connected to?
What firmware is running on it?
Is this a new setup?
Or what changed to cause this?
Pablo777
Sep 13, 2021Tutor
You have the R6400? Yes
What modem/gateway is it connected to? Twin Communications
What firmware is running on it? V1.0.4.106
Is this a new setup? No, but I had to reset the router because of a storm.
Or what changed to cause this? If I need to cconnect a new TV or cell phone, I have to reboot the router before it will work on that device.
On my main TV, it says "Connected, no Internet".
