androzz's avatar
androzz
Follower
Oct 03, 2022
Router problems
Why does my router disconnect from the internet so much? The service technician came out and said that sparklight isn’t having any problems at all on their end, but that the router signal keeps bouncing all over the place and he said something about a piece inside the router could be the cause. What exactly would be the cause inside the router? Also it seems that the internet disconnects frequently, but will come back on the moment I go into the nighthawk app, but I also have to always set up the router again every time I go into the app like I did when I first got it and it tells me it needs activation whenever it’s already been activated before. Can anyone explain it to me at all? I have a new one coming in on Monday to test if it’s actually a router problem or if it is on sparklights end.
1 Reply
  • FURRYe38's avatar
    What NG router and model# are you referring too?
