dhastings96's avatar
Apr 17, 2020
Router R6020 Not Providing Internet Modem Speed
Hello,   My internet provider is Spectrum and I am supposed to be getting download speeds of 200mbps.   After having a Spectrum technician out, they confirmed the modem is providing the correct s...
  • antinode's avatar
    antinode
    Apr 17, 2020
    > [...] And this limitation does not explain the slower wifi.
       Yes, it does.
    >    It does _not_ state that you can get more than 100Mb/s through the
    > "Fast Ethernet" WAN/Internet port of an R6080. [...]
    >    Live and learn?  A chain is only as strong as its weakest link.  The
    > fastest wireless stuff in the world can't suck bits through a "Fast
    > Ethernet" connection any faster than 100Mb/s. [...]
       You might be able to get faster data transfer between two wireless
    client devices on your own LAN, but any data going to/from the outside
    world passes through (your modem and) that 100Mb/s "Fast Ethernet"
    WAN/Internet port.
