dems
Apr 12, 2021Aspirant
Router R6020
Hello, I have some issue to connect Wifi module to the router. I would interested to know if there is way to retrieve the logs from the router. I need it to understand why the connection is reje...
Apr 12, 2021Guru - Experienced User
Page 101 of the manual goes over access the logs.
https://www.netgear.com/support/product/R6020.aspx
we can also potentially help but we'd need more info that what you've provided.
what modem/gateway is it connected to?
What device are you trying to connect to the wifi?
What error are you getting on the device?
Firmware on the router?
