dems
Apr 12, 2021Aspirant
Router R6020
Hello, I have some issue to connect Wifi module to the router. I would interested to know if there is way to retrieve the logs from the router. I need it to understand why the connection is reje...
Apr 12, 2021Guru - Experienced User
Page 101 of the manual goes over access the logs.
https://www.netgear.com/support/product/R6020.aspx
we can also potentially help but we'd need more info that what you've provided.
what modem/gateway is it connected to?
What device are you trying to connect to the wifi?
What error are you getting on the device?
Firmware on the router?
dems
Apr 13, 2021Aspirant
What modem/gateway is it connected to?
-> Router R6020
-> It is an embedded board
-> [WLAN access rejected: incorrect security] from MAC address ..........
Firmware on the router? -> V1.0.0.40
- plemansApr 13, 2021Guru - Experienced User
There is newer firmware.
R6020 | WiFi Router | NETGEAR Support
any special characters/spaces in the ssid or password? Not all Iot or imbedded devices play nicely with them.
