dems
Apr 12, 2021Aspirant
Router R6020
Hello, I have some issue to connect Wifi module to the router. I would interested to know if there is way to retrieve the logs from the router. I need it to understand why the connection is reje...
dems
Apr 13, 2021Aspirant
What modem/gateway is it connected to?
-> Router R6020
What device are you trying to connect to the wifi?
-> It is an embedded board
What error are you getting on the device?
-> [WLAN access rejected: incorrect security] from MAC address ..........
Firmware on the router? -> V1.0.0.40
Apr 13, 2021Guru - Experienced User
There is newer firmware.
R6020 | WiFi Router | NETGEAR Support
any special characters/spaces in the ssid or password? Not all Iot or imbedded devices play nicely with them.
