Simoch
Sep 30, 2021Aspirant
Router R6120 works only on some computers
HelloWe have a Problem since yestaerday. We installed Netgear router and everything was fine. Now I'm the only one haveing a working WiFi (I have a Mac). My friends has a Dell pc (with Widows 10) and...
Simoch
Thanks for the replay :)
It's connected to an internet source in the office, I dont know a lot about it.
Everything works on my MAC. So I think is probably window blocking something.
Firmware on the router? no idea
Do wired devices work? no idea
are you using access controls? no idea
what actual error do they get when they try to connect?
No error, it connects. Outlook simply doesn't work and sometimes browsers do not work as well
Sep 30, 2021Guru - Experienced User
Your work office?
I'd check with your IT department with how they'd like it setup to integrate with their network
