restlessru
Jul 29, 2021Follower
Router R6260 -NetGear 26
I am having trouble with my Netgrear 26 R6260.....when I trouble shoot it it says there is no driver to update? It will not connect my new printer? All lights are on it but it is not working?
michaelkenward
Jul 30, 2021Guru - Experienced User
What is this printer?
Connect how? Wifi or USB?
Have you installed the ReadySHARE Printer Utility?
How do I download and install the ReadySHARE Printer utility? | Answer | NETGEAR Support
Troubleshoot how? In Windows? If so, then I would believe that message. That is probably not the problem.
