Aville
Dec 26, 2020Aspirant
Router R6300V2 Guest Network Alert
The guest network display shows a yellow triangle alert. What does the alert mean? Firmware just updated today 12/16/2020
Dec 27, 2020Guru - Experienced User
Some more details or a screen shot might help.
Is this alert through windows/android/mac?
If you "hoover" over it alert, does it tell you what it is?
Does the guest network work?
- AvilleDec 27, 2020Aspirant
Hovering does not reveal anything.
The guest network does work.
This what you see when you open the Advanced tab on the Netgear Genie.
The picture didn't upload properly.
It is only showwing the yellow triangle alert.
That appears to the left of Guest Network (2.4GHz)
I will try again. Looks OK prior to sending
Screenshot of bottom of Advance Tab
OK, I can't figure out how to properly upload a jpg file.
Maybe it's my browser. I will try a few things.
