Birl
Mar 19, 2017Aspirant
Router R6400
Won't connect to the Internet. Connected to Spectrum modem. Spoke with spectrum they couldn't resolve. Said to call netgear. Any ideas?
- Mar 21, 2017
Birl wrote:
There is no mention of amber in the quick start guide for ethernet ports.If you read page 11 of the manual it says:
"The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections."
So, when you say:
I have an amber light on port 1 where my Arlo is connected.It means that the Arlo is operating at <Gigabit speeds.
michaelkenward
Mar 20, 2017Guru - Experienced User
Been through the troubleshooting bits of the manual?
>>>>> R6400 | Product | Support | NETGEAR <<<<<
Page 167 onwards.
And this?
>>>>> I cannot access the Internet with my NETGEAR router; what troubleshooting steps should I follow? <<<<<
- aalexandrebetaMar 20, 2017Master
I am a bit limited but Birl can you explain your network is wired and connected?
Draw a clear picture.
PLEASE!
