woodroad's avatar
woodroad
Follower
Dec 05, 2021
Router R7800
Just got Sonos speakers and they won't connect because of my router settings.  Message on Sonos app reads - if router setting is "N" or "AC" only change to B/G/N (MIXED).  How do i find out and how do I change?  PH
  • michaelkenward's avatar
    michaelkenward
    Sounds odd.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
    While you are at it, check this:
    Search - NETGEAR Communities – sonos
  • plemans's avatar
    It shouldn't be related to what setting the wifi is on.
    I've got a couple sonos speakers and they've connected to my AC and AX systems fine.
    What sonos speakers did you get?
    What modem/gateway is the router connected to?
