ijholmes
Oct 06, 2022Aspirant
Router Randomly Limiting LAN to 100M/Full. Wifi Works normally
So I havent used my computer in maybe 2 days, everything worked perfectly fine, i didnt update anything regarding the router, there was a windows update I did last time I tunred the computer off, but...
Oct 06, 2022Guru - Experienced User
You'll need to check your PC. If nothing changed on the router and only change was the PC, then you need to check the PC. Be sure the ethernet adapter drivers are updated. Ensure you have a supporting ethernet adapter that supports 1000Mpbs connection rates.
Be sure your using good quality LAN cable. CAT6 is recommended.
Try a different wired PC or laptop
- ijholmesOct 06, 2022Aspirant
shouldnt be the PC because when I go to from the modem to the PC directly I get full speeds. Also its more so the modem because its limiting ALL of my Lan ports to 100 automatically, doesn't make sense for it to just randomly at the same time do that coming from the PC.
- FURRYe38Oct 06, 2022Guru - Experienced User
Has a power off then back ON with the ISP modem and router been performed? Pull the power adapters for the modem and router then back in after one minute
Turn off and unplug modem.
Turn on computers and rest of network.What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.- ijholmesOct 07, 2022Aspirant
done all of this, forgot to note im an IT professional (Sys Engineer) and i've done all basic and obvious steps in a situation like this. looking for some more advanced possibilities as this has me stumped.
- michaelkenwardOct 07, 2022Guru - Experienced User
What is that modem?
Just to rule out possible issues.
