Jamop
Oct 10, 2021Aspirant
Router reboots
My 17 month old r6400 v2 reboots itself very frequently...2-3 time hourly. I have reset to factory and reinstalled; short term it helped but started same problem after several hours. Also cannot see ...
Jamop
Oct 11, 2021Aspirant
Firmware V1.0.4.120 connected to Netgear CM1000-100NAS ISP is Spectrum
Back story- replaced spectrum provided modem/router single box with this equipment 17 months ago based on recommendation of spectrum sevice rep who suggested a 2 box system as I was have a lot of outages. It worked well for several months but then problems resurfaced and have been escalating. I removed ethernet cable from router to tv adn connected it using wifi as tv stopped recieving singal via cable. I have since reset router to factory and reinstalled. No improvement. My next step may be to do another factory reset and change the names on my network to something new and different. I don't want to do this nor do i think it will help.
Jamop
screen shot of app on ipad. There are more than 7 devices connected; i can update descriptions and icon but it reverts back to this. Sometimes it will show only 1 or 2 devices with correct description and icon...I'm baffled
- wcalifasOct 14, 2021Prodigy
Try installing a different firmware to your router see if that helps. Also I'd try a different power adapter, maybe its failing. Just a few things to try and troubleshoot.
- LucianoMMNov 07, 2021Aspirant
I have the same problems.
If I test my conection (speedtest.com or fast.com), my router reboot it self. - LucianoMMNov 07, 2021Aspirant
I tried. Firmware Version 120, 102 and 98.
I noticed that the router was at a higher temperature. I turned on a fan and there was no restart, so far.
I redid the same speed test where the router restarted and it didn't happen again.
I will run more tests.
