bobm202
Feb 27, 2018Aspirant
router shows Amazon firestick and so does panasonic tv
Hello, I am puzzled . I can see my my printer on the tv net work and it shows it can connect but not using any password. If I remove security I can connect to tv with 2.4 or 5 ghz. but using any secu...
- Mar 14, 2018
Hello,
The panasonic TV lists all routers in my area and my Amazon Fire stick but would not let me conncect using a password through the TV., Why they show me The Amazon buit you cannot connect is a mystery. I finally just connected the TV using the WPS first and once the TV is connected I couild then connect the Amazon Firestick using the Amazon remote. Hopefully this might help someone else.
DexterJB
Mar 01, 2018NETGEAR Moderator
Hi bobm202,
1. What is the firmware version of the router?
2. To clarify, you are attempting to connect both the Panasonic TV and Amazon Firestick to the WiFi, correct?
3. Is the Panasonic TV WiFi capable or requires the Amazon Firestick? Please indicate the model number of the TV.
4. Have you tried changing the wireless channel of the router?
5. Have you tried resetting the router?
Dexter
Community Team
