bobm202
Feb 27, 2018Aspirant
router shows Amazon firestick and so does panasonic tv
Hello, I am puzzled . I can see my my printer on the tv net work and it shows it can connect but not using any password. If I remove security I can connect to tv with 2.4 or 5 ghz. but using any secu...
- Mar 14, 2018
Hello,
The panasonic TV lists all routers in my area and my Amazon Fire stick but would not let me conncect using a password through the TV., Why they show me The Amazon buit you cannot connect is a mystery. I finally just connected the TV using the WPS first and once the TV is connected I couild then connect the Amazon Firestick using the Amazon remote. Hopefully this might help someone else.
DexterJB
Mar 01, 2018NETGEAR Moderator
Hi bobm202,
1. What is the firmware version of the router?
2. To clarify, you are attempting to connect both the Panasonic TV and Amazon Firestick to the WiFi, correct?
3. Is the Panasonic TV WiFi capable or requires the Amazon Firestick? Please indicate the model number of the TV.
4. Have you tried changing the wireless channel of the router?
5. Have you tried resetting the router?
Dexter
Community Team
DexterJB
Mar 07, 2018NETGEAR Moderator
Hi bobm202,
1. For connecting the TV, you can check page 41 of the user manual linked below.
https://panasonic.encompass.com/shop/model_research_docs/?file=/MSC/om/TC40AS520U.pdf
2. Since you already have wireless devices that are able to detect and connect to your WiFi, the TV should be able to do the same by connecting to the WiFi name and using your WiFi password if you have it secured.
3. As for the Amazon Fire TV stick, you may refer to the link below for the steps on how to connect it to the WiFi.
https://www.amazon.com/gp/help/customer/display.html?nodeId=202104860
4. Please make sure that the TV along with the Amazon Fire TV stick are both close enough to detect the WiFi signal from the router.
Dexter
Community Team
- DexterJBMar 12, 2018NETGEAR Moderator
Hi bobm202,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- bobm202Mar 14, 2018Aspirant
Hello,
