bobm202
Feb 27, 2018Aspirant
router shows Amazon firestick and so does panasonic tv
Hello, I am puzzled . I can see my my printer on the tv net work and it shows it can connect but not using any password. If I remove security I can connect to tv with 2.4 or 5 ghz. but using any secu...
- Mar 14, 2018
Hello,
The panasonic TV lists all routers in my area and my Amazon Fire stick but would not let me conncect using a password through the TV., Why they show me The Amazon buit you cannot connect is a mystery. I finally just connected the TV using the WPS first and once the TV is connected I couild then connect the Amazon Firestick using the Amazon remote. Hopefully this might help someone else.
DexterJB
Mar 12, 2018NETGEAR Moderator
Hi bobm202,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
bobm202
Mar 14, 2018Aspirant
Hello,
