joenant's avatar
joenant
router signal fades and resumes, or fades and drops and then resumes.
My previous Netgear router had a strong, consistent signal, but my current one does not (age about 6 months); same Netgear model (WNDR3400v3). I read that sometimes having the modem and router close ...
  • joenant's avatar
    joenant
    Apr 08, 2016
    thank you.  I downloaded and also accessed netgear settings at which time discivered there was an update available which I downloaded.  interestingly that may have resolved the issue as the signal is now consistently strong.  thanks for your help and I now know what to look for in the future.
