WinstonJEC
Feb 22, 2018Tutor
Router speed does not match Modem
Hi, I'm having an issue with my R6100 router. It's not matching my ISP speeds like my modem does. If I plug my PC directly into my modem I pull 100+ mbp/s down every time. As soon as I direct plu...
- Feb 23, 2018
You may find this hard to believe, I do, but there is a 100 Mbps limit on the LAN speed of the R6100.
According to the manual it does:
LAN 10BASE-T or 100BASE-Tx, RJ-45
WAN 10BASE-T or 100BASE-Tx, RJ-45
This does not explain the speed loss you see – although you have to remember that the 100 Mbps covers everything that is going on on your network – but it does mean that you will never get the same speeds as devices that do 1000BASE-Tx. I didn't realise that Netgear still made 100BASE-Tx stuff.
michaelkenward
Feb 23, 2018Guru - Experienced User
- WinstonJECFeb 23, 2018Tutor
I know my router is older but I didn't realize that it didn't have gigabit ethernet, but I am also confused nonetheless why it's dropping 40 mbp/s since it "supports" 100. I've ordered a N750 which I know definitely supports it so I will be testing my internet speeds on Sunday to verify. I will follow up and let you know if that fixes my issue. Thank you very much!
- michaelkenwardFeb 23, 2018Guru - Experienced User
Who knows what it will do for your LAN speeds?
By the way, there is no such thing as an "N750". That is a label that Netgear uses to boast about the wifi speed of its hardware. N750 is also pretty old and slow.
- WinstonJECFeb 23, 2018TutorUnfortunately in my area there is nothing higher than 100 mbp/s so really any gigabit Ethernet would do the job. I don’t see the need to spend $150 for a newer router if this solves my issue. If it doesn’t... then I guess I will be spending $150!
