WinstonJEC's avatar
Feb 22, 2018
Router speed does not match Modem
Hi,   I'm having an issue with my R6100 router. It's not matching my ISP speeds like my modem does. If I plug my PC directly into my modem I pull 100+ mbp/s down every time. As soon as I direct plu...
  • michaelkenward's avatar
    Feb 23, 2018
    You may find this hard to believe, I do, but there is a 100 Mbps limit on the LAN speed of the R6100.
    According to the manual it does:
    LAN 10BASE-T or 100BASE-Tx, RJ-45
    WAN 10BASE-T or 100BASE-Tx, RJ-45
    This does not explain the speed loss you see – although you have to remember that the 100 Mbps covers everything that is going on on your network – but it does mean that you will never get the same speeds as devices that do 1000BASE-Tx. I didn't realise that Netgear still made 100BASE-Tx stuff.
