WinstonJEC
Feb 23, 2018Tutor
Router speed does not match Modem
Hi, I'm having an issue with my R6100 router. It's not matching my ISP speeds like my modem does. If I plug my PC directly into my modem I pull 100+ mbp/s down every time. As soon as I direct plu...
- Feb 23, 2018
You may find this hard to believe, I do, but there is a 100 Mbps limit on the LAN speed of the R6100.
According to the manual it does:
LAN 10BASE-T or 100BASE-Tx, RJ-45
WAN 10BASE-T or 100BASE-Tx, RJ-45
This does not explain the speed loss you see – although you have to remember that the 100 Mbps covers everything that is going on on your network – but it does mean that you will never get the same speeds as devices that do 1000BASE-Tx. I didn't realise that Netgear still made 100BASE-Tx stuff.
michaelkenward
Feb 23, 2018Guru - Experienced User
I've ordered a N750 which I know definitely supports it so I will be testing my internet speeds on Sunday to verify. I will follow up and let you know if that fixes my issue.
Who knows what it will do for your LAN speeds?
By the way, there is no such thing as an "N750". That is a label that Netgear uses to boast about the wifi speed of its hardware. N750 is also pretty old and slow.
WinstonJEC
Feb 23, 2018Tutor
Unfortunately in my area there is nothing higher than 100 mbp/s so really any gigabit Ethernet would do the job. I don’t see the need to spend $150 for a newer router if this solves my issue. If it doesn’t... then I guess I will be spending $150!
- michaelkenwardFeb 23, 2018Guru - Experienced User
Absolutely right.
My question was about this N750 thing. It isn't a Netgear, or anyone else's, model number, so no one can check if it might do the job.
Even if you don't have >100 Mbps Internet, your local traffic could swamp a modem/router link that is stuck at that speed. So I think you have made a wise move if you have ordered a router that does 1000 Mbps LAN.
- WinstonJECFeb 23, 2018TutorI apologize! I didn’t realize that wasn’t the model number. It is the Netgear WNDR4300 - will follow up on Sunday with results!
- WinstonJECFeb 26, 2018Tutor
Well, I guess that was the issue. I'm still not entirely sure why I would lose 40 mpb/s even without a gigabit port but I got my new router in and it immediately pulled 120 mbp/s. Thanks for the help!
