chuckputer
May 14, 2016Guide
Router speed G or N, N300 Router
I'm using a program called WiFi Info View for Windows to view some stats on routers in my area, and my router shows it is using 802.11G at a max speed of 54Mbps. Should not this router be showing me ...
- May 18, 2016
Is WMM enabled? You can find it in ADVANCED > Setup > QoS Setup on the router.
TheEther
May 16, 2016Guru
I recommend re-enabling it.
chuckputer
May 17, 2016Guide
I want to throw this into the mix....for the fun of it I decided to disconnect my wired machine (HP as well) and see what happens with a wireless connection. This uses a Qualcomm Atheros AR9485 802.11 b/g/n card. To my dismay, the results I see in ALL areas as you had me look at are exactly like my wife's HP w/ the Realtek card, including the 50% reduction in d/l speed on Speedtest. "Confused in South Carolina"
