chuckputer
May 14, 2016Guide
Router speed G or N, N300 Router
I'm using a program called WiFi Info View for Windows to view some stats on routers in my area, and my router shows it is using 802.11G at a max speed of 54Mbps. Should not this router be showing me ...
- May 18, 2016
Is WMM enabled? You can find it in ADVANCED > Setup > QoS Setup on the router.
TheEther
May 18, 2016Guru
chuckputer
May 18, 2016Guide
WMM was not enabled, it is now and I get:
WiFi Info View showing an 802.11n router @ max speed 300Mbps!
SpeedTest numbers on my wife's wireless rivaling my wired connection!
Windows advanced settings showing 802.11n protocol!
THANK YOU SO MUCH! CASE CLOSED!!!!
