sawalker's avatar
sawalker
Router speed is slower than my ISP
Recently, my ISP (Spectrum) increased my internet speed from 100Mbs to 200Mbs.  I had them come out and confirm that direclty out of the Spectrum modem I am in fact getting close to the 200Mbs speed....
  • michaelkenward's avatar
    michaelkenward
    Aug 12, 2018
    Wiseguju wrote:
    If i am not mistaken the WAN port on your router is only 10/100 port(max of 100Mbps), ...
    You are not mistaken.
    The manual for the WNDR3400v3 clearly says: WAN 10BASE-T or 100BASE-Tx, RJ-45
    >>> WNDR3400v3 | Product | Support | NETGEAR <<<
    The LAN has the same specs, which is slower than the LAN most PCs made in the past decade or so.
    This is a pretty basic and now slightly old (four years) variant of a router that first appeared in 2010.
    At least it does 5GHz radio, albeit on a slow wifi standard, N600.
