mbelaney's avatar
mbelaney
Follower
Jan 28, 2021
Router speed
how do i change my router to 5G setting?
1 Reply
  • plemans's avatar
    What router do you have?
    If you have a dual band router and it doesn't have smart connect, then its usually the phone/tablet/device that you choose which to connect to.
    But again, easier to know with model numbers.
    You can also go to netgear.com/support/   and type in a model number. it takes you to manuals, guides, etc
