tfox37380
Oct 01, 2021Aspirant
Router stopped working correctly
Last night my R6700v3 router stopped working correctly - only had power button and internet lights flashing white. Tried several reboots with no change. Finally tried a factory reset and worked for a...
- Oct 02, 2021
Did that (but had to disable Webshield on my AV) and finally got into my router. Rolled back the firmware to 106 and everything seems to be working now. Thanks for the help. Any word on when Netgear will get a firmware update that doesn't cause these issues?
tfox37380
Thanks for the advice, but I can't login to my router to backdate the firmware - routerlogin.net not working.
Oct 02, 2021Guru - Experienced User
Try using its IP address and not the routerlogin address.
- tfox37380Oct 02, 2021Aspirant
- plemansOct 03, 2021Guru - Experienced User
I haven't seen any updates from netgear at ll on it even though this issue has been across multiple product lines
