tfox37380's avatar
tfox37380
Router stopped working correctly
Last night my R6700v3 router stopped working correctly - only had power button and internet lights flashing white. Tried several reboots with no change. Finally tried a factory reset and worked for a...
  • tfox37380's avatar
    tfox37380
    Oct 02, 2021
    Did that (but had to disable Webshield on my AV) and finally got into my router. Rolled back the firmware to 106 and everything seems to be working now. Thanks for the help. Any word on when Netgear will get a firmware update that doesn't cause these issues?
