jawahl
Oct 13, 2016Aspirant
Router suddenly produces horrible download speeds
My router suddenly crapped out on me and it is just over a year old. I pay for 30 Mbps and can not get above 1 Mbps. It randomly happened a couple days ago and no performance altering factors have ch...
- Oct 13, 2016
Hello jawahl
Welcome to the community!
I suggest that you try to reflash the firmware of the router by downloading the latest firmware from our site and upload it to your unit.
Once done, factory reset the router then reconfigure it to get the internet connection back. Observe your connection and see if you'll get the same speed.
As a suggestion, try this on a wired computer first before proceeding on the wireless.
jawahl
Probably should have put my main concern closer to the top of the post;
Hardwiring to the router does NOT fix the problem, but hardwiring to the modem does.
netwrks
Oct 13, 2016Master
Try resetting your router to factory default. Reconfigure and try again.
- ElaineMOct 13, 2016NETGEAR Employee Retired
Hello jawahl
