dramyon
Oct 06, 2026Aspirant
Router web page doesn’t open
When I enter the up address for the router the connection times out. The up address shows up on a scan of the network but I cannot access the web page for the router. Factor reset made no difference....
- Oct 06, 2026
This on a ethernet connected PC to the router?
What Platform are you using to access the routers web page?
Try MS Edge, Firefox or Opera browsers?
Does a ping of the routers IP address work?
Try a 30-30-30 reset on the router with all ethernet connections disconnected?
What model is this router?
Oct 06, 2026Guru - Experienced User
dramyon
Firefox worked. Odd because I am replacing a model Netgear R6300 with another one due to an electrical issue. I have always used Chrome in the past.
- FURRYe38Oct 06, 2026Guru - Experienced User
Chrome may have changed something. I prefer to use MS Edge for router management or Firefox as back up.
Enjoy.
