littleman
Apr 20, 2017Follower
Router will not reconize ethernet cable at all
I come home from work and the regular DSL router had been blown from a storm that wasn't even a bad storm at all. The DSL modem was even pluged into a surge protecter. I got a new DSL box and when i ...
- Apr 20, 2017
More then likely you were hit on the phone line and it get your router by the lan cable. Even a surge protector will not stop a lightning hit if you are the target I have seen complete wired networks damage down to every nic card by mother naturals light show. If you are lucky you may be able recover the router if the firmware is the problem a hardware problem your out of luck. If more then the two item's listed in the posting are damage your home owners insurance may help in the cost of recovering.
William10a
Apr 20, 2017Master
