rmakin
Jul 02, 2022Guide
Router with SMA connectors
I am in a rural location and only have a Nighthawk MR1100 rented through AT&T for WIFI. It is about 5 yrs old and either it and/or the Orbi's keep disconnecting and losing internet so I think I need...
michaelkenward
Jul 03, 2022Guru - Experienced User
rmakin wrote:
Does Netgear have a modem, that has SMA connectors to enable a direct plug in for the external antennas, which would be an improvement over the MR1100 hotspot and could be used with an AT&T plan?
You are looking for something that will work with a Nighthawk MR1100 or something similar?
You could also ask for advice i the section where people talk about those devices.
That's probably here:
Mobile Routers, Hotspots & Modems
