QA_VA
Sep 10, 2022Follower
Router with stand alone hotspot
Is it possible to connect my N600 router to a hotspot? A hotspot is the only way for me to get internet that works.
Sep 11, 2022Guru - Experienced User
Are you talking a cellular hotspot? LIke using a phone or using a dedicated cellular router?
Its a bit important as if the hotspot doesn't have ethernet, then you wouldn't be able to connect the router to it.
So what actual device are you wanting to connect your router to?
