IDpotato2019's avatar
IDpotato2019
Router without a modem
Does a AC1000 need a connection to a modem to work as a router?  I want to connect some networked printers to a computer without a modem and I was wondering if the LAN worked without the modem connec...
  • antinode's avatar
    Mar 07, 2019
    > Does a AC1000 [...]
       "AC1000" is a speed, not a model number.  Ever helpful, Netgear
    product packaging emphasizes speeds like "ACxxxx", but that's not the
    model identifier.  Look at the product label for the actual model
    number.  "R6080"?
    > [...] need a connection to a modem to work as a router?
       No, if your "AC1000" _is_ a router.
       If your devices were all configured with static IP addresses, then
    you could use a simple network switch to connect them.  A router would
    (normally) provide a DHCP server, so that could be an advantage over a
    network switch.
