mynter
Dec 05, 2020Follower
Router WNR2000v2 Slow Internet
Hi everyone, Hope you guys can help me! I have a Spectrum modem which provides 100mbps (tested already). However, I connect it (with an Ethernet cable) to my WNR2000v2 router and my internet goes...
Dec 06, 2020Guru - Experienced User
If you're wanting faster wireless, you need to update the router.
The WNR2000v2 is a N300 device. Meaning its a single band device that runs on 2.4ghz. 2.4ghz is slow and sensitive to interference. For areas with many wifi networks 30mbps over 2.4ghz is actually considered a good speed.
For faster speeds, you'd want to upgrade to a dual band router. 5ghz is significantly faster and less sensitive to interference. Only downsides to it is that it doesn't broadcast as far or through as much materials as 2.4ghz.
https://kb.netgear.com/29396/What-is-the-difference-between-2-4-GHz-and-5-GHz-wireless-frequencies
wcalifas
Dec 08, 2020Prodigy
If I were you I'd upgrade to something newer, that will not give you the speeds you are paying for. Its a little old, you can still save it and use it as an access point but the newer routers can give you better output.
