Colinsk
Jul 09, 2017Aspirant
Router won't accept passwords
I bought two new Netgear WAC104 routers today. I am having the same problem with both. When I can get in on 192.168.0.100 I can make configuration changes. Mostly it DHCPs the server to 192.168.4.1 an...
- Jul 09, 2017
Here is the link for the access points http://www.downloads.netgear.com/files/GDC/WAC104/WAC104_UM_EN.pdf
You will need to start on page 12 and follow the instructions with a hardwired lan based computer one at a time.
Remember that you need to assigned a different ip address to each access point to so you login which one you want at the time.
William10a
Jul 09, 2017Master
