Stella0503
Oct 29, 2020Aspirant
Router won't connect to internet
I currently have an Airport Express Router and Extender. When I disconnect them and connect my new Orbi the exact same way, the Orbi says no internet connection. I have fiber internet and there is a ...
sbpbrent
Dec 26, 2020Aspirant
If the internet light doesn't stay lit once you have connected everything per the nighthawk app or the 192.168.1.1 direct login to the router, exchange your unit for another one. Do not call help support. Exchange your unit. You should get the internet light to stay lit in order to properly run the wizard to get your connection.
