Eldriken's avatar
Eldriken
Router won't stop rebooting...
I have a Netgear R6250 that I bought a while back. I bought it because the WiFi signal I was getting from my gateway from Comcast was absolutely pitiful. I figured maybe buying a router of my own to ...
  • VE6CGX's avatar
    VE6CGX
    Jun 24, 2016
    You already tried different wall wart. I'd try this, don't connect anything to the router. Power it off >> presss and hold down the
    reset button >> power up >> when lights flash, let go of reset button, does it make any difference? Mostly there are two things
    can cause symptom like this, over heating or bad power supply.  Speaking if power supply on the router board there is voltage
    regulator chip, electrolytic capacitors, etc. Thes component can go bad causing unstable voltage/current on the power rail.  If
    no matter what it acts like it, time to open it look inside. Look for suspicous component, check thermal paste under heat sink on
    cpu and radio chip, etc.
