mattmore1111111
Mar 29, 2022Star
Router working, can't access admin page
Router is working, and has been working. (Nighthawk, R6400v2, 802.11ac) Tried to access admin control panel via web browser, failed Tried alternate browser, failed Rebooted Router, problem persist...
- Apr 07, 2022
So, here is the solution:
Use paper clip to hold down the reset button for 10 seconds.
Router Restarts
Use wired device to connect to router at 192.168.1.1
Wait
Go through the new setup process as all of your settings gone.
Rebuild your router like you took it out of the box.
Hope it keeps working (not a lot of faith this problem won't happen again)
I already had the menu go into infinite wait screen and trying to reconnect the IP wasn't accessible. Power cycled and was able to get back in.
All I changed was a device name on the wired network (changed Playstation to Playstation 5 in the description, not device name, it did take effect though)
So.... there we go.
Thanks for all the help Netgear (sarcasm)
mattmore1111111
Mar 31, 2022Star
This is true. I used to do a lot of field service on Fortinet firewall/routers. After working on those home gear is mostly a walk in the park, except when the config interface won't come up.
I really wish i could console in to this netgear to work on it. CLI is generally better for these things or to figure out what isn't running or why.
mattmore1111111
Apr 07, 2022Star
Router Restarts
Wait
So.... there we go.
