mattmore1111111
Mar 29, 2022Star
Router working, can't access admin page
Router is working, and has been working. (Nighthawk, R6400v2, 802.11ac) Tried to access admin control panel via web browser, failed Tried alternate browser, failed Rebooted Router, problem persist...
- Apr 08, 2022
So, here is the solution:
Use paper clip to hold down the reset button for 10 seconds.
Router Restarts
Use wired device to connect to router at 192.168.1.1
Wait
Go through the new setup process as all of your settings gone.
Rebuild your router like you took it out of the box.
Hope it keeps working (not a lot of faith this problem won't happen again)
I already had the menu go into infinite wait screen and trying to reconnect the IP wasn't accessible. Power cycled and was able to get back in.
All I changed was a device name on the wired network (changed Playstation to Playstation 5 in the description, not device name, it did take effect though)
So.... there we go.
Thanks for all the help Netgear (sarcasm)
michaelkenward
Apr 08, 2022Guru - Experienced User
That was, of course, the suggestion made near the start of this conversation:
Solved: Re: Router working, can't access admin page - NETGEAR Communities
I see no sign of the "reset" word. Tried that?
mattmore1111111
Apr 08, 2022Star
If you continue reading you'll also note that I wanted to avoid this very thing with any kind of a solution to unstick the web interface that was permafrozen and inaccessible. The idea that rebooting the router didn't make the login interface accessible is absolutely horrible product.
My solution was dripping in sarcasm but you probably missed that as well.
...but hey, thanks for taking the time to point out something completely not needed. Hope it got you an extra netgear contribution point for your profile.
So, just for fun I re-parsed the entire thread.
You are quoting back my own post to me. Since I flagged it as a solution it will be inserted as the second post, and then the post when I wrote it in chronological order. The same post will be shown twice - as designed.
Good job.
